2008 PO Code 1260 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-28-2013, 05:31 AM Thread Starter
txhotrod's Avatar
2008 PO Code 1260
I have a 2008 PS with a PO1260 code. It will crank over normally like its going to start then something pops or clicks after that if just cranks real slow like a dead battery, with no start. I used a VOM and checked both batteries and they are both reading over 12volts. I hooked up my Snap-On scanner and it gives me a 1260 Theft deterrent code. The code will not clear. Anybody got any ideas?
txhotrod is offline
post #2 of 3 Old 06-01-2013, 12:47 PM
Powerstroke Techie
Ignore the P1260. That code in this strategy should prevent the truck from cranking altogether.
Check all connections to the starter, and at batteries, and if that looks good, try cranking it over with the jumper wire under the hood near the RH battery.
Does it crank over for a while before it does this, or like it's got a cylinder or two full of antifreeze or fuel?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 3 Old 06-02-2013, 05:20 AM Thread Starter
txhotrod's Avatar
FIXED! It was a CAC boot that had blown off.
txhotrod is offline
