High Deltas EOT and ECT with H&S - Ford Powerstroke Diesel Forum
post #1 of 64 Old 05-28-2013, 05:34 AM Thread Starter
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
Alright, so lately I have seen around 8* to 10* deltas while driving my normal 75 mph commuite to work. As oppsosed to my normal 6* I always see. Well this weekend we towed our fifth wheel up to the the Texas Hill country an dI saw on avaerage around 16* to 20* deltas when towing the trailer. Average air temp was 88* to 91*. I was seeing 199* ECT and 216* to 220* EOT. Is this normail when towing large trailer in the heat? Trailer weighs around 9000lbs to 10,000lbs. 30' in length. What could be causing this and how can I fix it? Also not sure this has anything to do with it but my tranny feels like the TC is slipping in 1st-4th before my TC locks up. May have to look into that. Nothing major just doesnt seem like it is holding real tight.
All mods in sig.
thanks in advance
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #2 of 64 Old 05-28-2013, 07:47 AM
Quoted: 45 Post(s)
Which trans tune are you running?
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #3 of 64 Old 05-28-2013, 08:44 AM Thread Starter
Quoted: 14 Post(s)
Trans tune, locks in 4th at 45mph, and locks straight into 5th at 55mph.
Just popped the hood a minute ago and it looks like I blew some coolant out the bottle it has a few white spots around it. Looks like I lost about 3/4" of coolant in the bottle. Im guessing thats not good huh?
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #4 of 64 Old 05-28-2013, 11:27 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Nope thats not good. Is your egr deleted? If so it will probably end up being head gaskets.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 64 Old 05-28-2013, 11:42 AM
Quoted: 45 Post(s)
Putting your first and second posts together, it sounds like you are about to have a bad day.
Sorry.
post #6 of 64 Old 05-28-2013, 01:40 PM Thread Starter
Quoted: 14 Post(s)
Ok, well if I did pop my head gaskets how will I know? Will it continue to puke out the degas bottle? or will coolant just vanish without leaking anywhere? I dont want to take it in and lay down a bunch of cash before I know for sure. Also are these temps here bad as far as highway towing?
This was constant for about a 2-1/2 hour drive?
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #7 of 64 Old 05-28-2013, 02:02 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
As the pressure in the cooling system rises it will continue to puke coolant. Your temps are not bad at all but that doesnt mean its not your head gaskets. You can either rig up a way to check the pressure in the coolant system or buy a block check to see if combustion gasses are in your coolant.
08 F350 cc/sb 4X4
post #8 of 64 Old 05-28-2013, 02:15 PM Thread Starter
Quoted: 14 Post(s)
Any chance it could have puked and not neccesarily popped the gaskets? Does that ever happen?
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #9 of 64 Old 05-28-2013, 02:16 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I guess it could if the coolant bottle was overfull. Also you could replace the degas bottle cap and see if that may be the problem. You never know.
08 F350 cc/sb 4X4
post #10 of 64 Old 05-28-2013, 02:19 PM Thread Starter
Quoted: 14 Post(s)
The bottle was about 1" over the full line, I got a new bottle because I had a crack in my old one and they over filled it a few weeks back. So that means I have a new cap on it as well. I will have to keep an eye on it and see. If i did pop a gasket am I going to ruing anything driving it? Just keep an eye on the coolant level?
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
