P0088 code after egr and dpf delete? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-14-2013, 07:58 AM Thread Starter
i recently installed a delete on the egr and the dpf 09 f350 and now after i drive 50 miles or so just crusing it go into limp mode or power loss and gives this code didnt have this problem before. any sugesstions on what may be causing this? also it seems to happen when its hot outside hasnt done it in the cooler part of the day. thanks
ez1racer is offline
post #2 of 4 Old 05-14-2013, 05:59 PM
Powerstroke Techie
Not related to your deletes likely.
Typically means the HPFP is going for a poop.
There is a reflash from Ford to correct this, but I have been told it's not very effective. Been out of the Ford repair world for a couple years now.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 4 Old 05-14-2013, 06:34 PM Thread Starter
I talked to someone at Gear Box where the tunner came from and they said they were having this issue and was testing a fix now and should have it by the end of the week. crossing my fingers. The truck was fine until i put these deltes on never got any codes at all. started this about 40 miles after i put it back on the road. also it does fine pretty much all day until the air temp outside gets hot. For sure runs better until it starts messing up. Thanks for replying
ez1racer is offline
post #4 of 4 Old 06-01-2013, 12:49 PM
Powerstroke Techie
So they are likely using a very old calibration in their flash tool.
