6.4L Boost - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-05-2013, 05:04 AM Thread Starter
Smile 6.4L Boost
Hi guys. New member! Just bought an '08 King Ranch F350 Crew Cab DR Super Duty with 38,000 miles, 6.4L, factory turbo, 4.10 rear end. Took it out last night on the interstate with cruise set at 65 MPH. Engine turned around 2000 rpm, but even on the flat terrain I was reading around 1 on the boost gage. Fuel mileage was between 13 & 14. Is this normal to have that level of boost without towing or hauling anything?
thanks in advance.
spud1223 is offline
post #2 of 5 Old 05-05-2013, 05:30 AM
superduty6.4's Avatar
That seems extremely low. I'm between 5 and 10 on flat ground. If there's a head wind I'm a bit higher.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 5 Old 05-05-2013, 05:36 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
Your boost is definitely low that truck is capable of 50. And I'm sure you can raise that mpg too.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 5 Old 05-05-2013, 05:47 AM
Maybe he meant the first mark on factory boost gauge. In that case it would be 10psi and close to what mine runs on the highway.
griz700rocket is offline
post #5 of 5 Old 05-05-2013, 05:58 AM
Quoted: 7 Post(s)
ahh i forget about factory ones.. you may be correct good call.
