Cruise Control Crapped Out, help?! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-27-2013, 05:38 AM Thread Starter
DieselPowerFan's Avatar
I have an '08 F250 Auto diesel, and my cruise is totally gone, worked the other day, and nothing last night, no lights in the dash (for the cruise control, all other lights/gauges are fine). Any help on where to troubleshoot would be great! thanks!
DieselPowerFan is offline
post #2 of 6 Old 04-27-2013, 07:09 PM
HM-8404's Avatar
There is a brake switch located on the bottom front of the master cylinder that is bad to go out. I had to replace mine. It's an easy fix and the part was about $45.
HM-8404 is offline
post #3 of 6 Old 04-27-2013, 09:21 PM Thread Starter
Perfect, thanks, I'll check that out!
post #4 of 6 Old 04-30-2013, 12:40 PM
Same issue here..replaced the brake switch under master cylinder and all is well.
dgibbs is offline
post #5 of 6 Old 05-17-2013, 11:13 AM
Do you have to drain the brake system to change it or is it a closed system
cogsch47 is offline
post #6 of 6 Old 05-17-2013, 11:17 AM
Quoted: 48 Post(s)
a little fluid will leak out, but no biggie
drunk on diesel is offline
