6.4 Head Gask - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-25-2013, 07:29 PM Thread Starter
6.4 Head Gask
Doing a cab off head job on a 2008 6.4 with 130K.
Deleting EGR and DPF/CAT
Using VicterReiz Black diamond gaskets
Using Cat Antifreeze.
Are there any other upgrades that should be done?
Any thing special to look out for?
Thanks in advance
delmer is offline
post #2 of 12 Old 04-26-2013, 02:14 AM
what year is the truck?
08 JOB 1 F-250 Lariat Crew Cab, S&B INTAKE, H&S Blk MAXX, 5" Flo PRO, EGR Delete, Air Dog 165, Upgraded Bellows, MBRP Intercooler pipe, 4" Down pipe, Tial Wastegate, OUO T bars, ARP studs, Bestop pwrbrds
***Legal Disclaimer: Anything I say about my vehicle on this website(Powerstroke.org), pertaining to modifications, is only to gain acceptance from my peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues.
08smoker08 is offline
post #3 of 12 Old 04-26-2013, 04:16 AM
If you have not done the work, switch gaskets to OEM. They are better than the Black Diamond....many people have had problems with them. Just a friendly FYI.
Good Luck
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 12 Old 04-26-2013, 04:20 AM
i have heard that Black Diamond makes the OEM gaskets. I had black diamond on for ~5k miles and then found out my heads were cracked. So i ended up going with OEM since they come with the stock heads. Just a FYI all the "NEW" heads are remans from FORD. You supposedly cannot get new heads from ford.
I would pressure test the heads or ensure that the place that is doing it has a warranty. Mine had to come back apart 5 k miles later due to craked heads. Luckily the guy warrantied his work and it only cost me parts....
Good luck,
post #5 of 12 Old 04-26-2013, 04:24 AM
oh sorry i see that its an 08 now, My bad,
I upgraded the:
-Degas bottle (one on the 09 and 10s
-radiator hoses (2 o-rings instead of one)
-thermostats
-waterpump
-get the injectors flow tested. (Mine were bad at 80K miles) (6 out of the 8 had low flow)
-tripple walled bellows
-High pressure pump Kit (see diesel power mag about wiring issues on the 08s) (wiring rubs and causes truck not to start)
-check the glow plugs.
-serpentine belts if they are originals
-you are studding correct?
post #6 of 12 Old 04-26-2013, 04:25 AM
diesel23's Avatar
Quoted: 9 Post(s)
Feedback Score: 14 reviews
as the boys said , stick to oem gaskets , You should make sure you have it get studded aswell ,if new gaskets are going in , and really all depends on what your expecting out of the truck , once cab off , good time for several items but generally only if money allows ( ported intake ,upgraded valve train, IH pistons ) LOL , and if your doing the work , maybe saturate the bolts to egr coolers etc ,so they are good to go when your ready to tear into it
diesel23 is offline
post #7 of 12 Old 04-26-2013, 04:27 AM
diesel23's Avatar
Quoted: 9 Post(s)
08smoker08 , hey bud love the disclaimer !! LOL , derail over
diesel23 is offline
post #8 of 12 Old 04-26-2013, 04:30 AM
Yeah i saw that on another guys sig and thought what the heck. Might as well.
thanks man,
Just trying to be accepted
post #9 of 12 Old 04-26-2013, 05:53 AM Thread Starter
OK Thanks
The front cover has a cavitation erosion about 1/4" in length. Is that enough to justify replacing it?
I have a picture but cannot get it to post here.
Would be glad to email it to someone for advice?
delmer is offline
post #10 of 12 Old 04-26-2013, 06:15 AM
Based on my previous posts you can guess my answer.
I would, Not worth the risk.
