Strange Turbo noise - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-21-2013, 08:48 PM Thread Starter
08andstroking's Avatar
Exclamation Strange Turbo noise
Hey Guys,
I've tried searching this problem and I can't seem to find an answer.
Issue 1) When I pull a hill or just go a little heavy on the pedal the I hear the turbos spooling but I also hear a very loud hissing. I'm thinking one of the boots on the turbo piping is leaking. I did a visual on all the ones I could see and no rips or anything. I did find oil on of the boots. It's the one on the driverside bottom. Issue 2) I can hear some metal on metal noise when excelling. What would cause the oil to be going into the piping and coming out of the bottom boot (can't find anything wrong with boot) It still builds pressure and has the same power as normal but I'm very concerned that a turbo is about to blow up. Any advise or insight would be greatly appreciated!!!
edit:stock truck no mods
08andstroking is offline
post #2 of 10 Old 04-22-2013, 07:47 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The ccv system is what is causing there to be oil in the intercooler boots. It does sound like you have a boost leak. Check the intercooler boots and the up pipes and firewall for soot. As for the metal noise i am not sure what that could be.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 10 Old 04-24-2013, 03:48 PM Thread Starter
I have yet to find a the source of the leak. The noise the turbo is making sounds like the internals spinning and not getting lubbed. I can't find anything wrong other than the noises. It's going into the Diesel shop on Monday. I'm praying nothing to serious is happening.
post #4 of 10 Old 04-24-2013, 06:03 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
9 times out of 10 its the right up pipe! or the lower cac tube
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #5 of 10 Old 05-03-2013, 10:18 PM
Capt dong's Avatar
Quoted: 5 Post(s)
kinda like a kazoo sound?
08 F250 KR
08 F250 XL
Capt dong is offline
post #6 of 10 Old 05-03-2013, 11:02 PM
what he said
cfd_shop is offline
post #7 of 10 Old 05-25-2013, 08:46 PM
Sharpknife's Avatar
I have just noticed a kazoo sound on my new to me 08 f450 thought it was air going through a cowling or over some other bluff body, but the more I hear it the more concerned I am that it is turbo related. Im not seeing any power issues but I havent pulled anything yet either.
Wht does the kazoo sound usually indicate?
Sharpknife is offline
post #8 of 10 Old 05-25-2013, 09:37 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
I had this problem too, I was sure it was the turbo. Turned out the Downpipe joint on the lower section has came lose. The noise was so bad I was sure the turbo was fvcked. Check your exhaust for any lose connections. Another member posted the same thread you did and I mentioned that, and that's what it was.
Did you try searching for similar posts?
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #9 of 10 Old 05-25-2013, 10:01 PM
Sharpknife's Avatar
Thanks Mts
I have done quite a bit ofsearching on the noise here and elsewhere.
There are alot of noises that can come from powerstrokes
Iwill check the exhaust and pipes.
I am taking her to my brother in laws shop for new tires all around Tuesday and we will investigate it in full. Not sure his lifts are up to the tasks but we will check everything out. I have an inner dual tire seperation issue that is going to be dealt with first.
post #10 of 10 Old 05-25-2013, 10:54 PM
mts678's Avatar
Quoted: 7 Post(s)
Cool man let us know! I hope that's all it is. Once I discovered it was the down pipe joint, that brick I was about sh!t turned into little ol fart lol. Good luck man and let us kno what you find.
Marshall
mts678 is offline
Tags
6.4 turbo problems
