P0620 - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 22 Old 04-20-2013, 10:33 PM Thread Starter
Tx_oft's Avatar
P0620
My battery light kept coming on and I noticed the voltage on my mini max dropping from time to time. Brand new batteries in the truck about a month ago so I assumed possibly the alternator. Recently having a stud job done i thought maybe a lose wire. Sure enough, the positive to the alternator was loose and had nearly arched the stub in two. Picked up a new alternator and installed it today. Now I have P0620 that won't go away. I've cleared it numerous times and it pops back up within a minute. Voltage reads 12.0-12.5 on my mini before cranking. After cranking it reads 13.3 all the time. I looked for loose connections, and blown fuses and had no luck. Any suggestions would be greatly appreciated.
Sent from AutoGuide.com App
2008 F-250 CCSB FX4, MINI MAX (HD300), K&N CAI, 4" MBRP, ARP STUDS, EGR DELETE, 6.0 ROCKER ARMS, N-FAB STEPS, 6" PRO COMP LIFT, 37X13.50X20 TOYO MT, SMOKED TAILS & 3RD BRAKE
Tx_oft is offline
post #2 of 22 Old 04-20-2013, 11:13 PM
KCCO!!
kells17's Avatar
Dual alternators?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 22 Old 04-20-2013, 11:44 PM Thread Starter
Tx_oft's Avatar
Single
Tx_oft is offline
post #4 of 22 Old 04-20-2013, 11:52 PM
KCCO!!
kells17's Avatar
Maybe PCM, have you cycled three times for possible re-learn configuration?
VA Strokers
757 Diesel
kells17 is offline
post #5 of 22 Old 04-20-2013, 11:57 PM Thread Starter
Tx_oft's Avatar
No. Cycle the key three times to trigger that? I'm not familiar with it.
Tx_oft is offline
post #6 of 22 Old 04-21-2013, 12:06 AM
KCCO!!
kells17's Avatar
Have a look....
Originally Posted by JUGERNAUT View Post
Check the operation of the charging system warning indicator in the instrument cluster (IC) as follows:
With the key in the OFF position, the charging system warning indicator should be off.
With the key in the ON position and the engine off, the charging system warning indicator should be on.
With the engine running, the charging system warning indicator should be off.
NOTE: The PCM requires 3 key cycles to re-learn the configuration.
P0620 Primary Generator Control Circuit PCM
did you check Check : Fusible link SDC02. sometimes they burn up when it fries
john galt likes this.
VA Strokers
757 Diesel
kells17 is offline
post #7 of 22 Old 04-21-2013, 12:49 AM Thread Starter
Tx_oft's Avatar
Ill give it a try.
Tx_oft is offline
post #8 of 22 Old 04-21-2013, 01:01 AM Thread Starter
Tx_oft's Avatar
No luck. Battery light still coming on less than a minute after start up. Cleared code, cycled key 3 times, started and same thing happened.
Tx_oft is offline
post #9 of 22 Old 04-21-2013, 02:02 AM
KCCO!!
kells17's Avatar
Hmmm...I could only imagine it being an open and or short circuit which is causing the PCM to throw that DTC. Maybe run a continuity test? Or disconnect batteries and try again.
VA Strokers
757 Diesel
kells17 is offline
post #10 of 22 Old 04-21-2013, 02:16 AM
KCCO!!
kells17's Avatar
I get off work here soon. I will take a look at mine and run a few test trials on something that might work, will get back to you before noon EST.
VA Strokers
757 Diesel
kells17 is offline
