Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum
Old 02-11-2008, 09:54 AM
Quazzar Quazzar is offline
08 f350 lack of power intermittently
I got a 6.4 L that at times the turbo just shuts down. Be riding around 65 and the boost gauge goes down to zero and trucks slows down.. Anyone else having similar problem? the only codes in the computer were thermostat stuck open p0128 and a over speed condition.
Old 02-11-2008, 09:58 AM
Barchetta Barchetta is offline
Dirty South Stroker
Send a message via AIM to Barchetta
Possible it could be in regen.
My boost gauage goes down to 0 when I am on the interstate and it hits regen.
Old 02-11-2008, 10:01 AM
TwinTurboStroker TwinTurboStroker is offline
Now, on to the race truck
.......what do you mean by "over speed condition"? Sounds like regen to me too, but are you haulin azz everywhere?
Old 02-12-2008, 05:20 PM
powerstrokes only powerstrokes only is offline
Mine has set this code too, I asked about it and they said everytime you go over 85 (I think) it sets a code, no big deal they said.
Old 02-16-2008, 01:02 PM
rakshak rakshak is offline
I have the same problem while i was towing a large 5th wheel with my 2008 f-450. Did not go over 70 , This has happened 3 times . The last time they said it was exhaust sensor. I am worried about towing with it again. I travel alot so I need to fix this problem.any ideas out there?
Old 02-19-2008, 06:11 PM
richardndawnc richardndawnc is offline
My truck has been doing this on and off since new-- it is at Ford now since last WED. today they have found that a MAP sensor is not reading right- its using a MAP sensor to read boost pressure as well as a boost sensor -if they do not read the same psi it will shut the fuel off because it is confused-- or thats the BS my service guy give me tonight anyways, they are going to order a sensor and have it in tommorrow and TRY to see if that fixes the problem -- I asked them why he just did not pull a new truck off the lot and try the one off of it -- and he just started stuttering --- um u m a h -- we can't do that -it aint right-- anyways I will keep u all posted on the outcome-
