engine oil temp goes higher since upper radiator hose - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-13-2013, 01:52 AM Thread Starter
I had a new upper radiator hose installed a couple weeks ago and now since then the oil temp goes to 220 on the highway with no load. what is the deal? any suggestions???
kmack08 is offline
post #2 of 17 Old 04-13-2013, 02:00 AM Thread Starter
oh and i have had the coolant drained 3 times in the past 12k miles. Radiator, lower rad hose, and now upper.
kmack08 is offline
post #3 of 17 Old 04-13-2013, 04:03 AM
mxrider777's Avatar
Could be your thermostat
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
sinister coolant filter
zerex elc coolant
edge insight
Egr Delete w/ coolant reroute
mxrider777 is offline
post #4 of 17 Old 04-13-2013, 05:02 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
oil temp or coolant temp is 220 if its oil temp it could be because you flushed so much through the coolant system that you loosened up debris and clogged up the oil cooler. also make sure your coolant mixture is right
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #5 of 17 Old 04-13-2013, 08:47 AM Thread Starter
is there a way to clean the oil cooler or is it just one of those things you just have to replace?
It is the oil temp
kmack08 is offline
post #6 of 17 Old 04-15-2013, 06:28 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
What is the difference between your coolant and oil temp? It sounds like you clogged your oil cooler. No you cant clean it. If its clogged it needs to be replaced.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 17 Old 04-27-2013, 09:27 AM
fords number is 15 degrees between oil and water temp. that is on the 6.0L and 6.4L.
if either number is out of the 15 degree range, the oil cooler has restrictions.
gold350 is offline
post #8 of 17 Old 04-28-2013, 12:51 PM Thread Starter
the coolant temp stays at 190. i am thinking of doing the bulletpoof diesel half kit. seems to be a better fix than the oe filter that could just clog up again. has anyone had any experience with this kit??
kmack08 is offline
post #9 of 17 Old 04-29-2013, 09:33 AM
gold350 is offline
post #10 of 17 Old 05-23-2013, 01:52 AM Thread Starter
Well after doing research and not wanting to take my truck to the dealer again. I ended up purchaseing and installing the BulletProof Diesel 6.4 half kit. It only took a few hours to install and now my oil temp has not gone over my coolant temp!
kmack08 is offline
