Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum
Old 02-07-2008, 04:07 PM
GnFnRs GnFnRs is offline
Low coolant
today i noticed that the heater in my truck wasn't getting hot. i checked the coolant level and it was low...took 2 gallons to fill it back up..no sign of where it's going. anyone else have this problem yet??
Old 02-07-2008, 04:11 PM
Marty Marty is online now
International Threat
Since this is in the 6.4 section...
Radiators on the 6.4's have been issues since day one. I'd get that checked out!
Is this for the 6.0 in your signature though?
BTpsd BTpsd is offline
IF it's a 6.0...Go underneath the truck and look up by the backside of the motor. Look around the back of the heads and starter, possibly on the transmission lines. If you can see coolant it could be the EGR cooler of cooler hose. I just had this problem in Dec. Warranty should cover it w/$100 deduct. The trick is getting a good tech to find the leak. Mine only leaked after warm up/cool down and left to sit in the cold. Good luck!
Old 02-07-2008, 04:54 PM
i'm sorry. it's my 2008 f350 work truck. it's a 6.4 with 27,000 miles on it..
Old 02-12-2008, 09:11 AM
TwinTurboStroker TwinTurboStroker is offline
Now, on to the race truck
Check behind the driverside front bumper and look at the frame rail.....thats probably where it is leaking......thats where mine is, it a simple chrimp on the radiator that "drips" out coolant
Old 02-19-2008, 05:38 PM
kehale kehale is offline
my coolant cap was almost falling off when I picked mine up. a few California highways later, i had about a half gallon missing.
Added some Zerex G-05 and distilled water, tightened the cap. No problems since.
Old 02-19-2008, 05:39 PM
Jon
Tournaments Won: 1
Posts: n/a
Any white smoke or coolant off the back of your motor?
Old 02-19-2008, 06:06 PM
richardndawnc richardndawnc is offline
my Radiator has been leaking for months -- I haer there may be a recall for it ,but for now I just keep a bottle of antifreeze in the tool box ,just in case.
Old 02-19-2008, 08:29 PM
mschn99 mschn99 is offline
the radiator by far has been the most common problem ive seen with the 6.4
Old 02-20-2008, 04:41 AM
Jon
Tournaments Won: 1
Posts: n/a
Alright
Had me cornfused with your sig.
