Need some 6.4 guru advice... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-09-2013, 06:25 AM Thread Starter
(2008 F350 KR) I was driving to work this morning and I started feeling some vibration like I had a flat. I pulled over to check and noticed a puff of smoke from the tail pipe. Tires looked fine so I got back in the car and noticed a definite misfire.
When I left this morning I thought the truck sounded just a tad rough but it drove fine while I dropped off the kids. I then filled up with gas (could be bad gas?) and set out on my 42 mile trip to work. About 8 miles into it is when the truck started shaking.
I do not have any check any lights and there was no overheating but there is definitely some kind of misfire going on.
I just put a scanner on it and I'm getting a P0302, Cylinder 2 misfire.
Am I screwed? What should I check/replace first?
Cajundude is offline
post #2 of 7 Old 04-09-2013, 06:39 AM
05_PSD_Erik's Avatar
Could be an electrical connection issue with injector 2 or more likely (in my opinion) a failing injector. Hence the white smoke.
Do you have any mods on the truck? Is it deleted? How many miles are on the truck? all this info will help for sure. Also, how old are the fuel filters? That would be the first place I would look into. Also, don;t drive it any more than absolutely needed at this point. Failing injector could lead to melted piston.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #3 of 7 Old 04-09-2013, 06:47 AM Thread Starter
Filters and oil replaced 5K ago, I'm due for an oil change and was going to do one this week, along with the filters. Truck has 127K on it and has 5" exhaust with H&S tuner.
post #4 of 7 Old 04-09-2013, 11:01 AM Thread Starter
Low compression in #2 and #7... Broken rocker hopefully...
post #5 of 7 Old 04-09-2013, 04:26 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
What do you mean you filled it with GAS? you mean diesel right?
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #6 of 7 Old 04-09-2013, 04:29 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
If you remove air filter and hear a clop clop clop will idling through intake it is bad rocker arms! this is a tune up on 6.4l at 100k rockers are because they where out! bad design. im doing 2 6.4 motors as we speak in my shop. thrust bearings gone in each.
A/C ASW A/W WINGS
post #7 of 7 Old 04-09-2013, 04:38 PM Thread Starter
That's the green nozzle right? Yea, I meant to say diesel, sorry.. Thanks for the heads up on the rockers!
