No power to starter solenoid $100 PayPal'd to anyone that can figure it out tonight - Ford Powerstroke Diesel Forum
post #1 of 23 Old 04-07-2013, 01:09 PM Thread Starter
2008 6.4
DPF delete with H&S
That's right.. $100 PayPal'd to anyone that can figure it out tonight, so that I can make it to work tomorrow.
I was cleaning out my truck today in the driveway. I used the on board Via Air to blow all the dog hair out of the truck. I was starting the truck intermittently as the air cycled on and off to keep the battery's good. With the truck off, I blew the dash from the passenger side. All around the stereo, steering column, and gauge cluster. After that it would not start. Maybe blowing the dash was coincidental.
Everything seems normal, just won't crank. (No power to the solenoid)
Battery's are semi-new, have 13 volts, and are connected to a charger while I work on it.
I checked and swapped all the fuses that I can determine are associated with the problem. (Both fuse boxes)
I swapped the starter relay.
There is no power to the starter solenoid when I turn the key.
I don't believe there is power switching the starter relay with the key, but it has power to it.
Disconnected the battery's for 20 minutes, no change.
Tried the "single wire disconnect starter jump" trick (EGT13)... cranks, won't start
There are no codes
Reprogrammed H&S several times
Disconnected and reconnected the transmitting range sensor
I'm out of ideas... Don't have time to screw with it... Hate to have it towed to the stealership tomorrow but don't know what to do.
Aaron871 is offline
post #2 of 23 Old 04-07-2013, 02:11 PM
44magnum's Avatar
Well I'm not familiar with the transmitting range sensor, but I would bet you blew something loose around the ignition. Try taking the cover off your steering column and make sure the electrical connection to the ignition cylinder is full seated. Since you can get the truck to crank with the help of a jumper wire, to me this sounds like a computer not telling the truck to start issue.
I assume you didn't change keys, and that the key will rotate all the way to the start position.
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #3 of 23 Old 04-07-2013, 02:21 PM Thread Starter
I unwrapped the dash, and checked the ignition cylinder connection, no difference.
Same key, and tried the spare, no difference. Anti theft is acting normal as far as I can tell.
Aaron871 is offline
post #4 of 23 Old 04-07-2013, 07:09 PM Thread Starter
Looks like a tow and car rental tomorrow.......
Aaron871 is offline
post #5 of 23 Old 04-07-2013, 07:35 PM
Not sure if things changed with the 6.4 but I had a very similar issue and it was a solenoid on my passenger side fender well that was acting up. I had to cross the terminals with a screw drive to start the truck
Matt
2000 F250 ccsb 86k
Pro Comp 6" lift
Stock engine... For now!!!
Hefel86 is offline
post #6 of 23 Old 04-07-2013, 07:42 PM
Or on the newer models the starter relay is under the dash
Matt
2000 F250 ccsb 86k
Pro Comp 6" lift
Hefel86 is offline
post #7 of 23 Old 04-08-2013, 05:18 PM
Try going from park to drive and back a few times, I had this same issue a few months back.
Christop73 is offline
post #8 of 23 Old 04-08-2013, 05:43 PM Thread Starter
I purchased the truck as a certified used vehicle. I'm still in my warranty.
Called for road side assistance, they said I'm out of warranty. Long story short, they entered my information into their system incorrectly and I had to prove to them what the actual contract said. That took all morning.... Truck was towed to the dealership at 11:00 AM
Dealership says "First of all, the fuel pump is bad. We will replace it and go from there". Warranty has authorized the repair, but will ship a pump so they don't have to pay retail price to the dealership. 3 days..... (I agree to purchase new fuel filters)
I call warranty, we have a discussion about cost effective decisions, they agree to purchase the pump from the dealership.
Truck is already out of the shop, so pump goes in tomorrow. Until then, we are riding in a car. It's good to drive a car once in a while to remind you why you didn't buy one.
Aaron871 is offline
post #9 of 23 Old 04-08-2013, 05:59 PM Thread Starter
Dog like trucks....
Aaron871 is offline
post #10 of 23 Old 04-08-2013, 07:20 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
LOL! I see you made the switch into the dodge! Hope everything turns out well for your truck!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
