Billowing white smoke/oil in exhaust!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-22-2013, 02:34 PM Thread Starter
2008 powerstroke... I was driving down the road and looked behind me and there is white smoke pouring out the exhaust. A closer inspection showed oil in the exhaust. I know for a fact that 2 injectors are going bad and I have the replacements, I just haven't put them in. I still have boost pressure and am not losing too much power but at idle it runs a little rough. I guess my questions are 1) is it the injectors that might be causing the smoke? 2) where are the #3 and #8 injectors located and how do I replace them? Steps on procedures would be very helpful. Thank you.
Schaffer6988 is offline
post #2 of 2 Old 03-26-2013, 06:50 AM
If you have oil in the exhaust it wouldnt be the injectors, wouldnt the more likely culprit be turbo seals? When they go the oil just pours into the exhaust pipe.
jimb726 is offline
