P0620. im confused! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-22-2013, 01:11 PM Thread Starter
fordborn's Avatar
P0620. im confused!
alright yall heres the story. last weekend my alternator fryed. just gave out. got a Job 1 6.4 powerstroke. so i put in a new, 200 amp alternator. its a single alternator, dual battery set up. now my battery light is on and the P0620 code has been set. even when i clear it, it ends up coming back. the code is for a generator control circuit malfunction. my alternator is charging at 14.2 volts steady. runs fine. no humming or weird noises. before i started working on it i checked my battery voltages. they were both at zero. dead as a doorknob. but their holding a charge fine now. i dont understand what this code means, ALLDATA and Mitchell dont say ****. going to talk to a ford commercial tech now, just wanted to see what yall had to say. thanks guys!
fordborn is offline
post #2 of 5 Old 03-22-2013, 06:42 PM
'086.4LDiEsEl''s Avatar
Quoted: 2 Post(s)
The first thing that comes to muy mind is a bad connection. Maybe someone who has encountered this issue could help yo out.
'086.4LDiEsEl' is offline
post #3 of 5 Old 03-25-2013, 01:57 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Check the operation of the charging system warning indicator in the instrument cluster (IC) as follows:
With the key in the OFF position, the charging system warning indicator should be off.
With the key in the ON position and the engine off, the charging system warning indicator should be on.
With the engine running, the charging system warning indicator should be off.
NOTE: The PCM requires 3 key cycles to re-learn the configuration.
P0620 Primary Generator Control Circuit PCM
did you check Check : Fusible link SDC02. sometimes they burn up when it fries
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #4 of 5 Old 04-11-2013, 05:06 AM
did you check Check : Fusible link SDC02. sometimes they burn up when it fries[/QUOTE]
Where would I find this fusible link SDC02?
08KR350 is offline
post #5 of 5 Old 09-26-2016, 08:16 AM
I know this is an old post but I'm having the same issue. I've checked everything on here plus more and cannot find anything that's wrong.
pscott80 is offline
