Surging Cold Start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-21-2013, 07:02 AM Thread Starter
BigGreen06's Avatar
Quoted: 100 Post(s)
Surging Cold Start
Past couple mornings I've been starting my truck to let her warm up before heading to work. I usually let her run for 10-15mins to warm up. The past mornings its been between 20*-28* around 0730-0830 and the truck seems to ramp up to High Idle within 2 mins of starting. However yesterday and today I've noticed while at Hi idle the truck starts surging and it seems to come and go until I tap the pedal to lower it down to normal Idle.
Not really sure if this is a big problem.
-2010 F350
-Just had the Fuel Filters changed
thanks.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #2 of 3 Old 03-21-2013, 07:41 AM
montana6.0's Avatar
Re: Surging Cold Start
Mine has done the same thing when its colder out. Its weird but mine usually does it before high idle then when it does high idle its fine.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #3 of 3 Old 03-21-2013, 07:54 AM
DoubleDpsd's Avatar
My 6.0 did the same thing a couple weeks ago. Was around 10-15* and it was certainly strange, no plug in. Literally ran out to push the brake in and hasn't done it since. It was changing pitch all over the place like it was trying to do a vane sweep before oil got up to temp.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
