Sitting uneven Left to Right - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-18-2013, 12:37 PM Thread Starter
Huffing Diesel Fumes
jallen3521's Avatar
Hey everyone I was wondering if anyone may have an idea and a possiable solution to why my truck is sitting uneven. So much that it is noticeable looking at it and measuring the wheel wells the Right side front sits 1" lower than the Left side front. I do have 2" spacers under the springs.. everything looks right and nothing looks out of place.
Any help you guys can give would be helpful at this point.
2008 F250 XLT 6.4L Lets just say it isn't stock..
Sold 04 F250 6.0L
Sold 97 F250 7.3L
jallen3521 is offline
post #2 of 10 Old 03-19-2013, 10:29 AM Thread Starter
jallen3521's Avatar
Anyone? Do you think maybe one spring is worn and the other isn't? Truck has just shy of 98,000mi
Sold 04 F250 6.0L
Sold 97 F250 7.3L
post #3 of 10 Old 03-19-2013, 10:32 AM
sprksonu's Avatar
my 6.0 is doing the same and have heard from many others that they are running into the same issue?
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #4 of 10 Old 03-19-2013, 12:23 PM Thread Starter
jallen3521's Avatar
Hopefully there is some insight out there then.
Sent from AutoGuide.com App
Sold 04 F250 6.0L
Sold 97 F250 7.3L
post #5 of 10 Old 03-30-2013, 09:05 PM Thread Starter
jallen3521's Avatar
After looking and measuring everything I came to the conclusion that one spring is weaker than the other. I measured both and one the coils are closer together. I will be ordering new springs and will update if that fixes it.
Sold 04 F250 6.0L
Sold 97 F250 7.3L
post #6 of 10 Old 03-31-2013, 05:44 AM
fordpwrstroke7's Avatar
It's common for the rear springs to (eventually) sit lower on the driver side due to the fuel tank. The front isn't as common. I bet if everyone on the forum measured their trucks though, each side would be at least slightly different on the majority of them.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #7 of 10 Old 03-31-2013, 06:12 AM Thread Starter
jallen3521's Avatar
It is the front and its the passenger side so it has nothing to do with fuel. It sits 1" lower than the drivers side. I measured the spacing between 9 of the coils and it was at least 1/2" difference for just 9 of the coils.
Sold 04 F250 6.0L
Sold 97 F250 7.3L
post #8 of 10 Old 03-31-2013, 06:43 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Lift it....get new shocks and springs.
Big_Smokey is offline
post #9 of 10 Old 03-31-2013, 06:03 PM
Right. Which is why I said the front isn't as common. Your front coil springs are worn out. Get new ones, whether they're stock or aftermarket. You can get Icon coils for under $300. Problem solved.
2008 F-350 CCLB
post #10 of 10 Old 03-31-2013, 07:05 PM
Yup, rough country 4.5" is only 650 and it's easy to do on your own... then you get all new shocks too.
SemperDiesel is offline
