No power steering and brakes - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-13-2013, 11:56 AM Thread Starter
Trackstand's Avatar
Went out to start my 2010 f350 this morning. turned the key n waited for the glow plug light to go out. started the truck and went to pull her out of the garage and it had no power steering and no power brakes. popped the hood and everything looks fine. shut her off and restarted it and all was fine. does anyone have any idea? truck has 53000 trouble free miles on her.
On a side note i spotted a small antifreeze leak right under the front of the motor.
I have no ESP. would this all be covered under the powertrain warranty?
Help
Thanks
2013 Dodge Ran 2500 4X4 crew cab long bed
Trackstand is offline
post #2 of 5 Old 03-14-2013, 02:23 PM Thread Starter
Trackstand's Avatar
Update. the brake and steering has not happened again but the truck is smoking about every 25-50 miles. its going into Willowbrook Ford Monday morning. it looks like there is oil in the antifreeze. WTF
post #3 of 5 Old 03-14-2013, 03:27 PM
Please update us after you get the truck repaired....I'm curious.
Good Luck,
Turbo Kidd
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 5 Old 03-15-2013, 06:09 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sounds like the oil cooler ruptured. Keep us posted.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 5 Old 03-20-2013, 08:12 AM Thread Starter
Trackstand's Avatar
Dealer says the lower radiator hose is bad. $490+ for them to do it. WAFJ I found the hose for $60 online. dealer says 3 hours to change it. anybody done one before? gonna do it when the weather breaks. they say no oil in the coolant or vise versa...
