code problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-02-2013, 02:51 PM Thread Starter
code problems
08 f450 king ranch 4.88 gear egr turned off dpf delete , banks six gun, iq display, e brake, banks ram air. Truck is rarley driven 39000 miles. A p252f an p1000 code came up. Cruise control would not work at that time. Loud exhaust drone noise started a week before. Maynot be exhaust noise. Could condesation in cold air cooler cause this.
roberson is offline
post #2 of 6 Old 03-02-2013, 03:09 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
check your oil level it is growing that code is oil overfull! this happens if fuel is leaking into the oil!!! if your oil is overfull with that dpf delete and there is no regen then you have a fuel leak in there!!!
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #3 of 6 Old 03-02-2013, 03:14 PM Thread Starter
Oil level fine.
roberson is offline
post #4 of 6 Old 03-02-2013, 09:49 PM
WoodBoy's Avatar
How do you have an egr/dpf delete? Banks doesnt make a tuner for either deletes do they?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 6 Old 03-03-2013, 04:18 AM Thread Starter
Used the gearbox x to run off revenue and egr. Then installed banks.
roberson is offline
post #6 of 6 Old 03-03-2013, 08:26 AM Thread Starter
Hooked to 37 ft toy jailer and hit interstate. It pulled hard to 85. I had it balls to the wall. No performance issue 40 psi boost 1056 exhaust temp. Still hear exhaust leak passager side engine bay. No codes. Taken it to oc welch Ford for oil leak coming from above starter.
roberson is offline
