Adding Coolant... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-28-2013, 08:17 PM Thread Starter
integrityinc's Avatar
Adding Coolant...
So, I've added coolant 2x in the last month. Twice I've noticed after the truck is at running temp the reservoir is empty. I'm no mechanic so I don't know if anything is wrong. I've had no problems at all so far with my truck, no codes, no abnormal noises, doesn't run rough, temp gauge always reads normal.
Do I have a reason to worry?
Any help or advice would be greatly appreciated!
integrityinc is offline
post #2 of 5 Old 03-01-2013, 03:52 PM
caliber1's Avatar
I have had to do the same, suspect the EGR cooler. Just got the delete kit in from FloPro today. Not wanting to take any chances with failure.
caliber1 is offline
post #3 of 5 Old 03-01-2013, 04:10 PM Thread Starter
I am running a Mini Max, I was under the impression they 'shut off' the EGR?? Does this sound right?
post #4 of 5 Old 03-01-2013, 09:15 PM Thread Starter
Adding Coolant...
So I had the truck in for a warranty issue today. They did an oil change, and in the notes it says they found a coolant leak that requires more diagnosis. Would've been nice for the service manager to mention something about that rather than me just happen to figure it out!
That would explain my loss of coolant issue tho.
Sent from AutoGuide.com App
post #5 of 5 Old 03-01-2013, 10:15 PM
srjd's Avatar
Quoted: 2 Post(s)
Even tho h&s shuts it off it can still leak coolant. If your not seeing any on the ground or white residue marks on the degas bottle it's most likely your egr. H&s just stops the valve from opening. Coolant is still running thru the coolers
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
