No heat, green wrench.... !!!!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-28-2013, 07:27 PM Thread Starter
Here we go...
I have a 2008 f-250, around 150,000 miles, I have had thermostats changed, water pump changed, belts changed, service done, and oil temp sensor changed, and the blend motor.
The problem still goes on...
While driving the truck for the first 20 - 30 min everything is ok. But... After that, the engine temp spikes, I get then"reduced engine power" light, and the green wrench light comes on. And the heat blows cold... Then warm for a few seconds.. Then back to cold.
Please help guys... I think the mechanic has gave up
Baker58 is offline
post #2 of 4 Old 02-28-2013, 09:22 PM
I'm not a master mechanic by any means, but could the ECT (Engine Coolant Temperature) sensor have anything to do with this? I see you don't mention having that replaced yet.
What codes is it throwing at the time?
B. Adams is offline
post #3 of 4 Old 02-28-2013, 10:38 PM Thread Starter
I'm sorry I did not mention that, but it was also replaced.
The truck is not throwing any codes...???
It also seams like the "cleaning exhaust filter" comes on a lot. And when it starts to clean it, it goes insane (see above)
Baker58 is offline
post #4 of 4 Old 03-01-2013, 07:47 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I have heard head gaskets can cause issues with the heat. Are you puking coolant?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
