help truck wont start and all guages were everywhere - Ford Powerstroke Diesel Forum
Old 02-11-2013, 03:27 PM
i drove it for 5 mins right now up the street it sat for maybe 3 mins and when i started it it had a super deep tone and sounded like the intercooler was humming, the mini maxx said initializing communications, none of the guages were working they were just bouncing the CEL, traction control light, and battery light came on. when i got home i turned it off and now it wont start nothing at all wont even turn over....ideas? batteries? please help guys
thank you David
Old 02-11-2013, 04:04 PM
i checked the batteries thyre at 12.5 volts i hooked up the scanner and it had two codes
U0073 control module communication bus off, and P2263 turbo boost system performance
when i went to plug the mini maxx back in it would not turn on so im guessing its the tuner
but the truck is running now let me know if any of you guys have experienced this type of thing with a tuner before
Old 02-12-2013, 12:35 AM
travish3 had if not the same, a very similiar issue with his mini max. I believe it first started off with a wiring issue with the obdii, then something else happened. Private message him.
Old 02-12-2013, 10:15 AM
Just talked to h&s tech support, they said its most likely the power cord they are sending me a new one hopefully it works
Old 02-12-2013, 11:38 AM
Yeah pretty sure the cord was his issue as well.If not, like i said just message him because he and i both went through some werid electrical problems with our trucks and he has/had h&s when he had his issues.
Old 02-14-2013, 10:05 PM
new wire tuner works!
