Airbag code 12 - Ford Powerstroke Diesel Forum
post #1 of 1 Old 01-28-2013, 06:50 AM Thread Starter
Airbag code 12
Well I've been getting the above code off and on for the past couple of months at random and it seems to be getting more common.
I've got an 08 F350 XLT job 3 with mini-maxx and DPF delete and running only mild tune, low shift point and low low-boost fueling level. I don't lay on the throttle much and always let it warm up before I drive anywhere (have to here since its so cold)
I replaced the batteries last month hoping it would correct the issue with no improvement. I have a 1 amp trickle charger wired up with my block heaters as well.
My mini-maxx is reading 14-14.3 for voltage very consistently.
Any suggestions? I'm tracking this as a lost battery feed error. WTH does that mean? Thanks in advance!
jerrmy is offline
