6.4 p2263 overboosting no power - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-25-2013, 06:16 AM Thread Starter
i have a 2008 6.4 egr delete, dpf delete, running a minimaxx, once it got cold out it starting acting up, i change the ebp sensor the other day...Ill be driving down the road doing 70km/h the truck will hit 40psi boost without bareley hitting the throttle and it sounds like my boost is spilling out....i still get the p2563 ebp code here and there but then i get the turbo circuit performance code...any suggestions??? i booked an appointment with ford because sudposeably they can trouble shoot whats causing the code with their computer??? true or false??? i need some help ive been down for over a month
RollinCoal705 is offline
post #2 of 7 Old 01-25-2013, 06:54 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
You should replace the map sensor. Did you clean the ebp tube when you replaced it? This should get rid of your problem.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 7 Old 01-25-2013, 06:58 AM Thread Starter
yeah i took the ebp tube off and cleaned it too, i havent changed the map sensor though, im going too go order one today forsure, i sprayed water and soap lastnight around my turbos too see if there was any serious leak, i had some bubbles coming out around the acctuator arm, but nothing major.....its hard too tell if theres anything air leaks with the truck running, im going too go into ford and get a map sensor ill get back too you and let you know thanks
post #4 of 7 Old 01-25-2013, 07:03 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem bud! Keep me posted. I bet the map sensor fixes your problem. While your at it you should pull out the IAT2 sensor and clean it also. Its right behind the map sensor. It also gets all gunked up from the egr and ccv.
08 F350 cc/sb 4X4
post #5 of 7 Old 01-26-2013, 05:08 PM Thread Starter
changed the MAP sensor and cleaned the one behind it which was caked..went and tried it and the trucks still not working.....really high boost and it doesnt go anywhere, i cant even drive down the road it just spools out....any ideas?
post #6 of 7 Old 03-08-2013, 06:55 PM
srjd's Avatar
Quoted: 2 Post(s)
Let me guess your egr is deleted? I've been dealing with this problem myself it only happens when it's cold out. If your egr is deleted the air isn't flowwing thru there enough and let's the tube freeze solid your exhaust will sometimes sound like a cummins and other times 40psi for no reason! The tube has to be relocated or heat wrapped somehow. I bet this is your problem type in 6.4 ebp tube frozen. In google lots of threads on it
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #7 of 7 Old 12-31-2014, 12:20 PM
so is there a way to fix the problem?
gippster3471 is offline
