Another leak question - Ford Powerstroke Diesel Forum
Old 01-20-2013, 02:12 PM
hey new to the forums here, i purchased a 2008 450 about a year ago from the dealer. Ive noticed that its leaving little leak marks in the street from what appears to be the radiator. i have done a dpf cat delete and cold air on the truck. i bought the extended warenty and am wondering if i should return it to stock. has anyone tried bringing there 6.4 in tuned under warranty/ should i be concerned about this small leak. any advice is greatly appreciated.
Old 01-20-2013, 04:56 PM
Powerstroke Techie
Depends on the dealer, really.
Yes, low radiator levels cause all sorts of other problems including melting egr coolers if they're still on the truck.
Old 01-20-2013, 06:14 PM
I understand that the low radiator levels can cause damage I'm just wondering were its such a small leak if I add more coolant will the truck be ok to make it thru a snowstorm were getting tomorow
Old 01-21-2013, 06:10 AM
Powerstroke Techie
You should be OK just keep an eye on the level. Mine has been leaking for a week or so, haven't been driving it much though.
Old 01-21-2013, 09:29 AM
Thanks man will do I added some coolant this am the trucks going in on wed to the shop ill let you know how I make out
