Water pump or leaky radiator hose - Ford Powerstroke Diesel Forum
Old 01-07-2013, 06:14 PM
It seems my truck is leaking antifreeze from below the truck I just noticed this over the weekend and in a rush I poured some antifreeze in and I filled over the fill line... Is that bad not to the top though anyway anyone else had antifreeze leaks and info on the price I am looking for to fix I have 1000 miles left on ford extended factory warning or whatever but have recently deleted the truck and put in a programmer any I go??
Sent from my iPhone using AutoGuide.com App
Old 01-15-2013, 07:48 AM
I'd say its the lower radiator hose.
Old 01-28-2013, 05:21 AM
Could be lower rad hose, thermostat housing or the water pump.
Old 01-28-2013, 06:41 PM
Powerstroke Techie
Feedback Score: 3 reviews
upper and lower radiator hoses leak with regularity on these trucks. It's a crap shoot on which one it'll be, honestly, just change them both while your at it.
Old 01-28-2013, 08:16 PM
When my pump went south, it was leaking onto the crank pulley, and trickling down and dripping off the bottom of the pulley onto the steering linkages. Crawl up under there and see where it's leaking. You should be able to see the upper hose and t-stat housing if you deleted the EGR. Check around the hose ends. Most likely that's your problem.
Old 01-29-2013, 02:44 AM
I just had mine in the dealer last week for a leak, turned out being the upper radiator hose.
Old 02-28-2013, 04:50 PM
Had mine pressure tested and replaced the o-ring on upper hose. would still leak but only while cold. rechecked and found a lose hose clamp on the egr cooler hose. tightened and leak gone.
Old 03-05-2013, 09:12 PM
Mine had several leaks when I bought it. I replaced both upper and lower hose. venturi tee clamp, and a clamp on the egr cooler. Like someone said before just look for the white staining and you'll find your leaks.
