| 6.4L Problems Forum Having Trouble? Post here |
Wiring HELP Recon Clearance lights!!!
I installed my recon smoked clearance lights but, i am not sure what wire to tap into for the parking lights. I looked for that smart connector that everyone says is in there, and i cant find it. Is it passenger side or drivers side. I tapped into a purple with white stripe wire, not it. Also, a purple and green stripe wire, that lights them, when the switch in the off or on position, but not in the auto lights position. Could anyone help me locate the wire needed in the passenger kick panel or where this darn plug is. The truck i have listed below is the truck I'm working on. Thanks guys!
I have installed multiple sets on 6.0's and I pulled the headlight knob out and tapped into the brown wire....idk if it would be different on the 08+ though.....
Well, i know that my ground is solid, being that its on the same ground as the rest of the kick panel. Anyone else have some say on the 6.4? I still may try the brown if needed.
i always thought it was in the kick panel / sill plate pass side for the 6.4 also
directions were pretty clear when i did my 6.0 that wire lights the parking lights so it can't lie or dim ETC ps I wouldn't be surprised if the issue is on the Recon side |
Ive seen that forum of the installation, thank you, but i still cant find that plug. Thats where i first learned of the plug. I hate wiring lol
