New HPFP and truck dies when I accelerate it, makes weird noise. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-14-2012, 06:58 PM Thread Starter
Replaced the HPFP today with radiator and oil cooler, when I start the truck and put in drive if I accelerate it dies, once it runs for a couple of minutes I can drive it around no problem but it makes a noise like when a tv channel is offline when the turbo boost is over 10#. Is throwing code p0087 What the hell did I do wrong? Any ideas guys?
Steinbrenner is offline
post #2 of 3 Old 12-16-2012, 09:55 AM
P0087 - low rail pressure
Might be air in your fuel system now? Did you cycle the key on/off 4-5 times to prime the fuel system? I just changed my filters out yesterday and I cycled the key on for about 30 seconds each time until the tank stopped burbling.
Also double check to make sure the filter is fully seated, maybe it's sucking air past it.
Alaskan_awd is offline
post #3 of 3 Old 12-17-2012, 05:55 PM
Could be fuel leak in the HPFP fuel lines.
Did you replace the lines and gaskets per replacement procedures. Did you reset ECM fuel parameters per Ford service manual.
What code did you have before replacement? Was it P0088 only?
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
