Changing a HPFP need info - Ford Powerstroke Diesel Forum
Old 12-07-2012, 07:23 PM
What all tools are needed to change the pump?
Other than the gasket/harness is there anything needed?
Old 12-08-2012, 09:55 AM
Powerstroke Techie
Feedback Score: 3 reviews
a good brand new 10mm socket for removing the up-pipe bolts
are you removing the cab or the trans? If you are not I would recommend removing the turbos to better access the pump cover. I have done it cab on without removing the turbos or trans and i would not recommend it
there is a HPFP gasket kit that comes with new pump cover gasket, o-ring and new fuel lines to each bank. Get that if you haven't. Also if you're removing the turbos get the turbo hardware kit.
Old 12-09-2012, 04:53 PM
doing it with cab on. What about the tools to bleed the lines?
