| 6.4L Problems Forum Having Trouble? Post here |
Truck won't start after new HPFP
Have an 08 f250. Truck shut off going down the road. Got towed to my place and it had a p0088 code. I knew these trucks were bad about hpfp. So I replaced pump and now still won't crank. What should my steps be?
You need to bleed the high pressure fuel system. There is a special tool to allow the air to pass thru and out the inlet side of the fuel cooler.
Did you replace the pump cover gasket/harness also? |
Where can I get that tool? And I have been draining out of the valve on the fuel cooler. And yes I did replace the cover gasket/harness
Also why would it just die while I was driving it? And not restart?
Did you try an start it after the code was cleared? I had a battery that was shorting out, causing a surge. Shut my truck off while driving to save all the modules from frying. If i deleted the code it would fire up again. Had nothing to do with HPFP though.
