| 6.4L Problems Forum Having Trouble? Post here |
damn you oil!
Today my oil light came on after start up and truck was at temp. Then went off under load. It didn't come back till after I left in it 2 hrs. later and it was at temp again. The light only comes on at a stop. 1200 miles on oil change and a Motor Craft filter. Oil checks out good. Been reading and they say the pump are known to go out as is the oil pressure sensor. What gives? No CEL or warnings. Seems to run fine even at a stop.
And now i let it sit for about 1 hr....came out to leave and when I turned it on the oil icon was on only for about 3 sec. and I never saw it again on my way home.
what ended up being your issue? Im having the same issue
Oil bypassing the sensor working it's way up into the connector. I disconnected it an sprayed break cleaner into the sensor and plug to harness. Once that was done it came back 2 times and never saw it again. I'll break down for a new sensor in time.
Where is the sensor?
Sent from my SPH-D710 using AutoGuide.Com Free App |
DTS Articles - Coffee Table Books Down load this and it's everything you need to find what you want on the 6.4.
The book for the 6.4 is at the bottom of the page. when you click on it it will down load automatically.
Thanks the connector looked pretty clean on mine, i sprayed some cleaner in it, it didn't come on when I started it but then started it again later and it came on for 15 seconds or so , guess I'll see what happens may change the sensor monday if I can get one
Good luck to you!
To make a long story short I did have the same issue just went ahead and replaced the sensor though it was only 30 bucks, but thanks for the info I'm sure the dealer would have charged me a pretty penny
