White smoke... - Ford Powerstroke Diesel Forum
Old 11-13-2012, 05:26 AM
White smoke...
I'm blowing white smoke every now and then. Happened 4 or 5 times....WTF?
Stock 09 F250 with 45000 on the clock.
Any help.....
Tanks......
Old 11-13-2012, 02:48 PM
SOMETIMES when the truck decides to start a regen WITHOUT reaching operating temperature you MAY see some white smoke (This is unburned fuel). Since your truck is stock probably this is the case. Next time this happens make sure to take a look at your instrument panel to see if the truck is cleaning the exhaust filter.
Old 11-14-2012, 01:06 AM
Thanks for the intel, I will try to watch. I do know at least one time it had done a regen a few prior but not sure.
I wasnt sure because it was like I was leaving a smoke ploom....which will be ok when I get my DPF delete and tuner but not stock.
Old 11-26-2012, 09:37 AM
DPF delete & tuner will cure it. Regen causing it most likely - mine used to billow white smoke around town in regen cycle, drove me nuts! H&S tuner & DPF delete cured it with the benefits of a tuner (hp & torq boost). Drives like a new truck!
Old 11-26-2012, 02:48 PM
GRI GRI is offline
mine did it today. less than a mile down the road. no cleaning exhaust filter message either. i noticed my coolant was low an inch or two. this is the secoond time i added a quart of coolant. and the third time i saw white smoke
Old 11-29-2012, 04:40 PM
GRI GRI is offline
added a quart of coolant 2 more times. The truck is at the ford dealer now. no word on their diagnostic. but it is still under the powertrain warranty.
it started blowing white smoke all the time
Old 12-04-2012, 04:47 PM
My coolant was an inch or so low. The dealer checked everything out and no issues (computer, pressure check....) Filled the coolant up and advised to watch it......
Old 12-05-2012, 02:15 AM
GRI GRI is offline
the dealer is trying to deny warranty because they say I have a cold air intake. I guess by the previous owner putting a K&N sticker on the stock box is a CAI. But I am trying to figure out how that makes the egr cooler leak.
