water separator light after car wash? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-29-2012, 03:06 AM Thread Starter
08 f350 38k so saturday I went to the car wash and about 1/2 a mile after leaving the Drain water separator light came on, so I pulled over in a parking lot and got underneath the truck and opened it. Nothing came out (was parked level or slightly uphill with about 1/8 to 1/4 tank of fuel. I had the key off but when it was open I think i heard air bubbling or moving. Start it up no light for about 10 miles. So I went to fill it up and on the way home from the gas station the light came on. So when I got home I opened it up again and this time a decent stream of fuel came out. I didn't notice water though.
Next day after maybe 10 miles the light came back on, got where I was going and shut the truck off. then when I got back in and started it up it was off, after some driving back on again.
Is it just a coincidence that it happened after the car wash? Is something in there that would cause it not to drain anything when parked uphill or with less than a half tank?
If I bring it to the dealer with the DPF off the truck will they give me problems or should I just assume its dirty/clogged and do the repair myself? Or did the car wash mess up the sensor somehow?
2000 F350 (7.3l)
2003 F550 (7.3l)
2004 f550 (6.0l)
2005 f750 (Cat C-7)
2006 f250 (6.0l)
2008 f350 (6.4l)
JasonZ is offline
post #2 of 19 Old 10-29-2012, 07:30 AM
superduty6.4's Avatar
Something is plugging up the spout on the bottom. You should get something to poke up there and see if that helps and if not then the cap should be pulled off asap and the bowl should be cleaned out.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 19 Old 10-29-2012, 10:11 AM Thread Starter
I did get fuel out though with the full tank. I would clean it now but with the hurricane and full tank it's gonna have to wait
2000 F350 (7.3l)
2003 F550 (7.3l)
2004 f550 (6.0l)
2005 f750 (Cat C-7)
2006 f250 (6.0l)
2008 f350 (6.4l)
JasonZ is offline
post #4 of 19 Old 10-29-2012, 10:12 AM Thread Starter
Also I need a gasket right? Should I just replace the sensor while its all apart?
2000 F350 (7.3l)
2003 F550 (7.3l)
2004 f550 (6.0l)
2005 f750 (Cat C-7)
2006 f250 (6.0l)
2008 f350 (6.4l)
JasonZ is offline
post #5 of 19 Old 10-29-2012, 11:05 AM
I could be wrong but I don't think it will matter if the fuel tank is full, half, quarter etc. because there should always be fuel in the so it can feed the hpfp. Also the filter kits come with gaskets so I don't know if you can get them separate.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #6 of 19 Old 10-29-2012, 12:50 PM Thread Starter
oh you mean the filter itself? I had ford put one in about 800 miles ago when it was in for the radiator, they wouldn't have cleaned it out at the same time?
2000 F350 (7.3l)
2003 F550 (7.3l)
2004 f550 (6.0l)
2005 f750 (Cat C-7)
2006 f250 (6.0l)
2008 f350 (6.4l)
JasonZ is offline
post #7 of 19 Old 10-29-2012, 01:40 PM
I would think they would have. That's why I would try open the lever again and try stick a pin or something up there. If they just changed the filter then more than likely it is just something caught in the little nozzle.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #8 of 19 Old 10-30-2012, 03:38 PM
Quoted: 2 Post(s)
Check this out.
DTS Articles - Fuel Coagulation
My light wouldn't go off and I drained it several times. Did everything in the article and no issues since.
713Diesel is offline
post #9 of 19 Old 10-31-2012, 03:38 AM Thread Starter
Okay this is where I get confused. Am I removing the filter and just cleaning inside or am I removing the whole unit? Also I guess the car wash was just a coincidence?
2000 F350 (7.3l)
2003 F550 (7.3l)
2004 f550 (6.0l)
2005 f750 (Cat C-7)
2006 f250 (6.0l)
2008 f350 (6.4l)
JasonZ is offline
post #10 of 19 Old 10-31-2012, 12:01 PM
Quoted: 2 Post(s)
There is a cover plate on the unit that you drain the water our of that is held in by three torque screws I believe. This is where you can clean out the bowl. I replaced my sensor as well. I would go get the rebuild kit as they say you aren't supposed to reuse the gasket. If my memory serves me correctly I think I picked up both for a hundred bucks...... maybe a little less.
