Smelling coolant - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-21-2012, 04:16 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Smelling coolant
So I just started smelling coolant when I get done running my truck, my coolant reservoir was a little low today and everything looks dry. Is there anything I should check? Thanks!
2015 f350 cclb platinum...5% tint, Anzo smoked mirror lights, recon clear cabs, tgc 2.5" spacers, carli adjustable track bar, icon 5" rear blocks, Firestone riderites, B&W goosneck, line x, rancho 7000s, Fuel Mavericks wrapped in Toyo MT's, No Limit stage 2 cold air intake, 4" flo pro straight pipe, Sct w gearhead tunes, hideaway LEDs
salnazzaro is offline
post #2 of 12 Old 10-21-2012, 04:49 PM
sledfreak's Avatar
Unfortunately,I am in the same boat,for about 20,000 miles,ford has pressure tested it 3 different times and it holds,i personally think it's the upper radiator hose, but since the test holds 3 different dealers have done nothing.Please let me know how it turns out,as i have just about gave up,until something blows up and i go postal on the dealers that did nothing.
08 6.4 250 cc sb lariat loaded white/tan 4x4
H&S Mini HD 300
MCC tunes
7 Kem tunes
Gearhead tunes
AFE S2 SI
Flow-Pro 4"SS
Turbo back
Areo-turbine xl
3"mbrp ci pipe
ccv mod
sledfreak is offline
post #3 of 12 Old 10-21-2012, 05:00 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Ok that really makes me have no confidence in taking it in to get checked!
post #4 of 12 Old 10-21-2012, 05:25 PM
I had the same issue and was in fact the upper radiator hose. The original hose has one oring and Ford put out a fix what for it, two orings in the the hose ends.
Tidalwaters is offline
post #5 of 12 Old 10-21-2012, 06:04 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Alright i'll look into getting a new radiator hose maybe
post #6 of 12 Old 10-21-2012, 06:07 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
replace all three if you're going into it. the upper and 2 lowers will leak at any time if they haven't already been replaced with the new design. The lower is a 2 piece hose and the half that connects to the engine is as common as the upper. It's wise to change the whole thing though.
I frequently see these hoses as the cause for coolant loss. As hot as the 6.4 engine bay gets you may never get a visible leak on the ground. The telltale is white staininig around the hose connections, check your EGR cooler hoses too.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 12 Old 10-22-2012, 05:45 AM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Ok will do thanks for the info I'll have my mechanic check it out
post #8 of 12 Old 10-22-2012, 03:02 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
I'm just taking a guess after looking at the hoses that its gonna be a PITA since there's no room for a pinky anywhere under the hood.
post #9 of 12 Old 10-23-2012, 12:57 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Found the leak, got on it on the way home today and coolant was dripping when I got home and its coming from the bottom corner drivers side of the radiator, my truck got a new radiator at 36,000 miles the day after I bought it, just what I didn't want it to be!
post #10 of 12 Old 10-23-2012, 03:14 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Any suggestions on a radiator?
