| 6.4L Problems Forum Having Trouble? Post here |
Climate Control Head Dead
My batts went on me today, I installed new batteries and now I have no climate controls at all. Everything else works except for that. I checked all fuses in truck and under hood they are all fine. Is there a reset or so
Etching I'm missing or a hung relay??? Sent from my Autoguide iPhone app |
Electric automatic a/c controls I assume?
**EDIT** Either way you need to get section 412-00 of the Service Manual regarding diagnostics and testing. It will walk you through lots of tests to test every circuit that could cause that problem on either automatic or manual a/c's. You can find a link to a downloadable copy of the service manual if you search here for 'service manual' in the 6.4 sections. That section is a long one but downloading the entire manual will be very beneficial to you in the long run and this section is a good one to get you used to using the service manual if you have never seen one before. Last edited by f250Jason; 09-22-2012 at 06:27 PM. |
Thanks for the info.
