EGR delete problem NEED HELP ASAP! - Ford Powerstroke Diesel Forum
Old 08-08-2012, 09:24 AM
I was installing a flo-pro egr delete on my 08 and got it all done and started her up and coolant was pouring from around the upper coolant block off plate, thought it was the O-ring, took it back apart only to see the o-ring was fine. got to looking and see a small crack in the cast piece that the plug goes into. can someone please tell me what this cast piece is or a part number. has anyone replaced it and how hard is it?? thank you
Old 08-09-2012, 04:37 AM
Contact Your local dealer and they can fax or email you an exploded pic of the parts. Match it to what is cracked and they can give u a cost of the part and how much labor time they charge. It would give u a better idea on how difficult it will be to replace.
Old 08-09-2012, 07:18 AM
Go to Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com. You can get exploded views of all systems with part numbers and prices.
Old 08-09-2012, 07:40 AM
Like I said in the other thread, your timing cover is cracked, 500-600 for the cover and gasket and 400-500 for the labor.
Old 08-09-2012, 10:24 PM
like i replied in the other thread. it is just an elbow that is bolted to the timing cover. popped the elbow off there and the delete plug bolted right in to where the elbow bolted. free fix thanks for all the tips guys!
