No trailer lights just like that. - Ford Powerstroke Diesel Forum
Old 08-04-2012, 04:13 AM
Trailer pigtail worked perfect until I hooked a buddy boat up to my truck. It worked for a while and now just running lights no blinkers, brakes and can't find a bad relay or blown fuse. Anyone with this problem?
Old 08-04-2012, 08:06 PM
Send a message via Yahoo to upd103 Send a message via Skype™ to upd103
You checked the brake, turn relay for the truck and the tow module both right?
Not trying to question you, just saying to remember there are two.
Old 08-04-2012, 08:08 PM
is it the same for any trailer, runners but no signals?
Old 08-05-2012, 03:57 AM
Yes sir I checked all fuses and tested the relays. It does it on all my trailers and my buddy's trailer. It sucks azz.
Old 08-05-2012, 06:15 AM
Look into your wiring or your connector
Sent from my DROID BIONIC against my will
Old 08-05-2012, 06:28 AM
How are you testing fuses? Just looking at them won't cut it.
Check for power at the rear truck connector first. Then go backwards from there.
Old 08-06-2012, 05:14 PM
Checked the plug first and checked fuses for continuity with my meter. Tested the relays using meter and 12v battery
