| 6.4L Problems Forum Having Trouble? Post here |
Coolant issue
Hey guys got a little issue with my truck, truck is 2010 6.4 27k all stock. I notice my coolant is black, first thought was my oil cooler was leaking so I brought it to the dealer they said the coolant is burnt they reccomended a flush. They asked if I had a tuner I said no, so they said it could be just from regenning. Is this true? Shouldn't they cover the flush since it should be able to handle the heat of the motor? Any input is great guys thanks!!
No clue, but interested in what is causing it- subscribed. Hope somebody can chime in with some help!
Bump Sent from iPhone |
iv never seem coolant be "burnt" , thats why im thinking its either oil or something along those lines. Never seen it in any cars iv worked on, i dont work on diesels so not sure if coolant could get burnt from the egr coolers when the exhaust gets hot from regen. The way i see it is that the dealership is just blowing smoke up my a$$ and not wanting to do warrenty work
I'd send a sample off to someone. Not sure if Blackstone will test coolant, but you could try.
got any pics? my coolant is nasty. doing a flush soon. i know theres a lot of sand and rust.
do you have an updated upper radiator pipe? |
I would also send off a sample and see what it is. It wont do any good to flush it if there is a problem that needs to be corrected first.
Does blackstone sample coolant or just oil? If they don't who does?
I would call blackstone and ask. I am pretty sure they can sample it.
google them and check out their website im pretty sure they test everything oil coolant transmission etc. Sounds like it might be the oil cooler...i forget if someone asked but what are your deltas
