P0703 Code - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-16-2012, 01:27 PM Thread Starter
hammer67's Avatar
P0703 Code
I am getting ready to go on a trip this week & my truck started acting funny. I have a 2008 F350 4X4 with EGR by pass, exhaust filter removed (test tube) & black max programmer other than that its stock. The problem is the cruse will not set when the truck throws a code it says P0703 Brake switch B Circuit I have replaced the break light switch and checked all bulbs & plugged in my trailer & all is good so what is my problem. some times if I pull over shut the truck off then start it again all is good. There is NO check engine light on
hammer67 is offline
post #2 of 3 Old 07-18-2012, 06:42 PM
srjd's Avatar
Quoted: 2 Post(s)
Do a search on the diesel stop somone had the fix on there
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 3 Old 07-18-2012, 07:21 PM Thread Starter
hammer67's Avatar
Thanks for the info. This morning I did a search for P0703 & they said it was the brake switch under the hood. I replaced the switch & life is good again.
hammer67 is offline
