Hello, new the forum...Help! - Ford Powerstroke Diesel Forum
Old 07-05-2012, 05:27 AM
Unhappy Hello, new the forum...Help!
Hello as the title stated, I am new to the forum. I am also new to powerstrokes. I bought a 2008 6.4 about a month ago. I have added a mini maxx, a s&b intake, a 4" dp back diamond eye straight exhaust, and sinister egr delete. I run the truck in stock tune 98% of time. I like coolant at right tunes or higher boost (headgaskets), I already put a new degas cap on the truck. It now also has a radiator leak. I need help in the local area installing. I am on the northside of Indianapolis, Indiana. Oh 107,000 miles
Old 07-05-2012, 06:25 AM
If you did all the other work yourself you can change your own radiator. I would go with one of the aftermarket ones though cause the OEM ones fail alot. Take you about 3hrs to do yourself.
Old 07-05-2012, 07:23 AM
I was looking at a few of the lifetime radiators. Vista and performance radiator were also ones I looked at. No OEM radiator going back in, not with the ongoing troubles I have been reading about. Are the Vista or Performance radiators a OE fit? I will install the radiator myself. I just don't have a lift or facility to do the ARP headstuds and Black Onix headgaskets.
Old 07-05-2012, 07:57 AM
There is a recent thread discussing the aftermarket radiators. Search aftermarket radiator I believe there is a couple different options. Can not give any advice on the headgaskets, but I do believe alot of guys are saying OEM gaskets are the way to go with studs.
Old 07-05-2012, 08:31 AM
Ok stay with factory gaskets. So is it mainly the head bolts stretching and the heads lifting that cause the over pressure in the degas tank?
Old 07-05-2012, 09:08 AM
The way I understand it is the only two ways you get puking out the degas bottle and your cap is good is if you have a bad EGR cooler or blown headgaskets. There are alot of threads on here about this topic and people with more knowledge will probaly chime in. So far I have been lucky as far as headgaskets.
Old 07-05-2012, 09:16 AM
If you post your headgasket questions in the performance section you will get more answers.
Old 07-05-2012, 09:44 AM
i have heard good things about the vista pro radiators. I also heard someone mention Griffin radiators. I am not sure about them tho. Also stick with OEM headgaskets. Black onxy seem to fail even if the head is properly prepped.
Old 07-05-2012, 01:48 PM
Is there anyone in the northside Indianapolis, Indiana area that forum members would recommend for a cab lift and head gasket/ stud job? It can be business or personal diesel tech. All help is appreciated.
Thank you all for your help. If this thread is in the wrong place, please advise.
Old 07-05-2012, 01:51 PM
I know it was stated above already but be sure to go with oem gaskets not black onyx
