| 6.4L Problems Forum Having Trouble? Post here |
High deltas 20k after flush & ELC
20k miles ago I had my radiator replaced and did a flush and refilled with cat ELC. I have had a coolant filter for the last 2-3k, but I've just noticed high deltas. I replaced my t-stats last weekend thinking one must have been hanging up, but my deltas didn't change. On the interstate I'm seeing 15 to 17 degrees deltas. The largest I've ever seen before my was 8 or 10 degrees unloaded.
My question is, could it be something other than my oil cooler? |
Slowly climbed up. I towed 3 1/2 hours today and my delta stayed 19-21. Coolant was 203~ oil 223~
dang maybe that flush caused an oil cooler clog.
Can you check for any codes? Usually the temp sensor issue would cause the temp to show really high. If there aren't any codes then I guess it is plugged. When you did your original flush did you use the restore & restore +?
I thought if its going to clog after a flush it wouldn't have taken that long? Now I'm paranoid again! Lol
Today I towed back and my temps were dead at 204 ect and 224 eot. Ect would hit 206 for 10-15 seconds after a steep hill but drop right back down with no change in eot. I have a mod friendly dealer by my house and I've had a few conversations with one of the techs, so I'm going there tomo to talk with him and see if we can push it through warranty. I'm under warranty for another 20k, so hopefully we can get something done. I know there is an issue, I just hope ford will take care of it and not give me the usual "your 20 degree deltas are fine" crap. Btw, how hard is it to change a 6.4 oil cooler yourself? |
I hear you. I have a coolant filter also. I love this truck and have done all the preventative maintenance (minus egr cooler delete-coming soon) and I'm still having issues.
If you didnt do a chemical flush i cant imagine that the flush clogged the oil cooler. When you start your truck are the ECT and EOT temps pretty close? If so i dont think its the sensor. It sounds like its your oil cooler. Its not easy to do yourself. Its a cab off repair.
