Temp gauge pegging????? - Ford Powerstroke Diesel Forum
Old 06-06-2012, 06:31 PM
A friend of mine has an 08 with a 6.4, when the temp gauge gets up to normal position it then immediatly pegs out and the truck goes into limp mode. Has anyone seen this before
Old 06-06-2012, 08:19 PM
Check all the electrical plugs and grounds. Check especially the ECM connections and the like. I worked on a Duramax that did that and it was a corroded pin in the main harness connector on top of the engine. Check the obvious like coolant level and proper circulation.
