Gas in Diesel - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-26-2012, 10:10 AM Thread Starter
Gas in Diesel
I have a 6.4L a customer put gas instead of diesel. i replaced the high pressure fuel pump, all injectors, and fuel pressure rail sensor i also bled all the air out of the fuel system and it still wont run. i checked the cranking fuel pressure and reads 1200 psi then drops to 400 psi can anyone help.
6.4powerstroketech is offline
post #2 of 4 Old 06-01-2012, 12:34 PM
Quoted: 2 Post(s)
try posting the General Discussion 6.4L thread.. it will get a lot more attention in there not too many people read the problem forums
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 4 Old 06-01-2012, 05:38 PM
Is this the same 6.4powerstroketech that kept badmouthing the 6.4? I thought he knew everything..
forddude343 is offline
post #4 of 4 Old 06-01-2012, 05:58 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I would think a leak if it just drops.
Please tell me you cleaned the tank and all the lines and HFCM and all that too.
4R100, 2wd
330,000 + miles
jesilvas is offline
