Coolant Problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-15-2012, 08:53 AM Thread Starter
BigGreen06's Avatar
Quoted: 101 Post(s)
Coolant Problem
I'm not sure if this is a big issue now, or if it'll become a big problem down the road. My coolant level in my reservoir seems to drop below the line every 5000 miles. Not sure where it is going or if it is normal, but my last 2 oil chngs they had to pit more coolant in.
Another thing I noticed is my coolant temps on the hwy seem to be a.little high, or at least I think they are high @ 200-202* doing 80, and 196-198* doing 75. My DOT also goes up but stays within 5* of the coolant. I had the trans flushed 2k ago, but only dropped the temp 2* while under 65, and it heats up slower, but just seems like the.coolant solution is struggling to keep cool.
James
Sent from my ADR6400L using AutoGuide.com App
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #2 of 5 Old 05-15-2012, 11:19 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Does your truck smoke white? Do you see coolant leaking anywhere? A good place to start would be either the radiator or one of the coolant hoses. Also your coolant temps dont seem too high depending on the outside temp.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 5 Old 05-15-2012, 12:03 PM Thread Starter
BigGreen06's Avatar
Quoted: 101 Post(s)
No to the White smoke and visible coolant leaks. The temps have been between 60*-85*. I just didn't know what a 'Danger' temp would be.
James.
Accufab Elbow
LineX in the Bed
post #4 of 5 Old 05-15-2012, 12:05 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I believe the engine fan comes on about 220*. Its hard to say where the coolant is leaking from. It could be the hoses, the radiator or it could be a leaking egr cooler.
08 F350 cc/sb 4X4
post #5 of 5 Old 05-15-2012, 04:53 PM
peteoreo's Avatar
Make sure your coolant is not going in your oil.. We had one come in for coolant (08) and it had a sand hole in front cover behind water pump leaking to oil .
Trucks,Guns,Harleys
2013 FX4 Lariat Supercab 8ft box/Westin-HDX grill guard/H&S minimax/DPF/cat/delete/afe4 inch exh/Rancho 4 inch lift/1250x35x20s
peteoreo is offline
