| 6.4L Problems Forum Having Trouble? Post here |
dpf delete problem
i have problem with my sct livewire...was good until i put the dpf delete without any sensor....do i have to put it back.... is evry sct livewire have a dpf delete.. cause i cant find anything....and its always on cleaning filter mode...and white smoke comming out....this also make the pegt run like 1400...
any advice |
put the last end egt and the white smoke problem is ok....but still have the cleaning system problem that cause the egt to climb a lot... realize that when i put it back to parking, cleaning system goes off for a minute or so et temp goes down... So obviously this is my Sct that has not dpf delete option... im gonna try to put all other sensor for now but im not gonna let it like that for too long...
can i update my sct to have the dpf delete??? if so, where can i find the wire to plug it to usb cause i only got the one that plug into the obd2 |
You must be trying to run PDF on tunes. You HAVE to have PDF off tunes to run no dpf
you most likely are running dpf on tunes. sct no longer does dpf delete tunes so their probably not on there. you will need some custom tunes......
where can i get those custom tune... also i bought that sct used and i aint got the wire... is it possible to find it...
i might just buy a new tuner tommorow cause its seems complicated and i want to ride the truck
you have some reccomendation for a new tuner?
H&S & Spartan seem to be the two most popular ones. Pick one of them.
Actually it depends on how much you want to spend because the are less expensive tuners out there but they come with less "options" & some people say they are harder on stuff. I ran an edge race evolution for quite some time with 0 issues & it only ran me about $475 or somewhere in that range.
