| 6.4L Problems Forum Having Trouble? Post here |
Coolant Sludge??
I have a 10' f250 which isn't using any coolant. Coolant and oil temps are stable during driving, but there seems to be a sludge building up in upper part of degas bottle I'm still under warrenty so was wondering what this might be been tuned since 1800mi have 29k on now. Thanks
Pics please. "sludge" can mean different things to dif people.
I agree with the pics needed. Is it like a hardness buildup, that you would see on like maybe a showerhead, a slightly see through scale on the degas bottle? When I think of sludge, I think of like a mud water mix....So we need a little more....
I'll try to get you pics hard to get inside of degas bottle. It's like a brown staining on inside of degas where coolant level is when hot. Above cold fill range.
Like stated above it can be several things. Could be a leaking oil cooler or it could be rust or scale. Either way i would recommend a coolant filter.
Update I fished a long q-tip in there and it's a black and oily not scaly. So what would cause oil in degas bottle?
Most likely you need a new oil cooler do you have anything to monitor eot and egt
In my 7.3, oil in the coolant was an oil cooler.
Yeah have a cs from edge oil and coolant always in the mid 190's. Crawled up and looked in the degas looks more like a red/brown scale in the bottle with a couple area's dirty black. Guess it's time to put the DPF back on and to the dealer. Any way to check oil cooler??
You can monitor the difference between the coolant and oil temps. If oil is in the coolant is more than likely and oil cooler failure.
