Limited Slip is GONE - Ford Powerstroke Diesel Forum
Old 03-11-2012, 07:12 AM
Like I said, the Limited Slip has turned into unlimited slip. When I get on it to hard my passenger side rear tire lights up and thats all she wrote. Whats the most cost effective way to remedy this issue and is there anything good to do in the front. I almost got stuck yesterday on flat ground in a grassy field towing a tandem axle trailer with a Nissan Quest mini van loaded on it.
Old 03-11-2012, 07:34 AM
There is an old trick of putting one foot on the brake and the other on the throttle, using the brakes to slow the spining wheel, forcing some power to the other wheel. Thats the cheap ghetto way, your other option is to either rebuild or replace your LS diff. I would recommend replacing with a Detroit tru-trac ( badazz clutchless limited slip), but not cheap.
Old 03-11-2012, 07:38 AM
yea thats what I'm looking at. Summit has one for the ford 10.5" which is what I think I have for $540. I wonder what labor would be to install
Old 03-11-2012, 07:46 AM
Wow. Already burnt up? Mine still works after all these years.
Did you just change the diff fluid?
Old 03-11-2012, 07:56 AM
no I have never changed the diff fluid. It has 96k miles on it.
Old 03-11-2012, 07:57 AM
Im going to change the diff fluid front and rear and the transfer case at 100K
Old 03-11-2012, 10:18 AM
Well I was just asking cause it requires the LS additive.
Old 03-11-2012, 10:32 AM
Powerstroke Techie
Feedback Score: 3 reviews
I'll be honest it took me an hour to install my trutrac but I put on new carrier bearings before I started. I took a pattern and checked backlash after I was done and it was fine. No adjustments needed.
If you want someone to take measurements and use new shims it's going to take a bit longer but a lot of times this isn't necessary.
Old 03-11-2012, 01:21 PM
well I'm just a little scared of doing it I guess. Never been in a rear end before... truck or woman
Old 03-11-2012, 03:34 PM
its not too bad, you get used to it quick. and the truck ain't too bad either I've never taken a rear apart on a truck but as usual take your time and watch videos with step throughs
