Veh. Overspeed dtc - Ford Powerstroke Diesel Forum
Old 02-28-2012, 12:53 PM
Veh. Overspeed dtc
P0297, i searched but did not find my answer. What is this code ca
used from. I took the truck up to around 100mph but it didnt feel like it had the same punch as before. Got home, checked for codes and had the p0297, will this code reduce power.
Brian
Old 03-02-2012, 07:24 AM
29 views and nobody knows
Old 03-02-2012, 07:34 AM
Diesel Addict
Send a message via MSN to CanuckF350
Not sure if it will reduce your power, however you can clear it then change the setting on your speed limiter and it should not come up again.
