Radiator Leak...... HELP! - Ford Powerstroke Diesel Forum
post #1 of 37 Old 02-24-2012, 11:14 AM Thread Starter
Leaking coolant around the driver side lower corner of the radiator. Looks to be coming from the back side of the radiator (closest to the fan). I have read several threads and everything is mix matched about this. Is this something that can be corrected if it is caught early enough? Or am I SOL and have to fork out hundreds for a new one. I am at 97,000 miles and this is the first one that has went bad. From what everyone else has been saying on the forums, I seem to be really lucky for this to be my first radiator problem.
sckingranch is offline
post #2 of 37 Old 02-24-2012, 05:51 PM
I am assuming you have a 08-10 yr model truck...I am on my 3rd 08 model and they all have had the radiator issue. 97,000...boy you are lucky! My first one was around 40,000. Always the same side just as yours. The radiator is covered only up to 3yr/36K but if you have a good dealer you use regularly, they may help with this one as there have been thousands of radiators replaced. I have a friend who had 3 in one year.
sknotts71 is offline
post #3 of 37 Old 02-24-2012, 07:44 PM Thread Starter
Yes, it is an 08. Do you know what I am looking at as far as replacement cost? Is there anyway to patch it?
post #4 of 37 Old 02-25-2012, 08:34 AM
My local dealer has a labor rate of $73.20 an hour. I would figure FoMoCo will allow them 3 hours to pull and 3 hours to replace the radiator, plus coolant fee plus the actual radiator. Im thinking over a $1,000 easy. Man I would fight this to the bitter end. Ford gave us the crappiest powertrain in history(debateable with 6.0) and they need to make it right for you. Ford knows they have replaced at least 100,000 of these radiators due to the tank seperating from the radiator. It infuriates me to type this because it is a joke. A $63K vehicle and it has so many issues. They should have lifetime warranties on these vehicles. Beautiful trucks and solid from the windshield cowling to the rear but the weak link 6.4 has killed the truck. Are you the original owner?
post #5 of 37 Old 02-25-2012, 09:54 AM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
You might get lucky and take it to the dealer and they will replace it, even though you are out of warranty, I have heard of a few people getting this done free of charge because of the TSB issued on it and how many they have had to replace. It is worth a shot going to talk to a good dealer. If not I wouldnt replace it with the factory one, I cant remember who but someone has come out with an aftermarket radiator for these trucks. Good luck.
PS the driver side lower edge is the #1 place for them to start leaking so that will help you when talking to Ford.
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #6 of 37 Old 02-26-2012, 02:05 PM Thread Starter
Thanks for the advice. Yeah, I am going to go meet with the service manager at my local dealership and I will update once I know something. It deffinately has to be fixed soon because I have to fill the degas bottle twice a week.
post #7 of 37 Old 02-27-2012, 07:10 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
If it is not covered under warranty look at performance radiator
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 37 Old 03-03-2012, 06:30 PM Thread Starter
So heres the latest. I took my truck into ford thursday morning, and they tore into it and determined that yes indeed the radiator had to be replaced. She told me that if they got in there and saw that the thermostat was cracked, then it would all be covered under warranty. If not, then $1452.00. Anyways, the thermostats were not cracked and so I will be paying for the repairs.
Good news is, while the mechanic was in there he found that my entire egr manifold was cracked. Well warranty covered that, however I am still stuck with the radiator bill. I was very pleased because if he wouldn't have found that, and i would have drove another few thousand miles and it act up, I would have been paying a few thousand for that as well.
Also she said that she would talk to the service manager about helping me out some with the $1452. So hopefully I will get it at least under 1000.
Thanks for the advice guys...
post #9 of 37 Old 03-03-2012, 07:13 PM
Change your thermostats!!!!! I work on 24 ambulances we stopped having trouble when we did the venturi recall and changed thermostats.
Sent from my MB860 using AutoGuide.com App
ambulancedoc is offline
post #10 of 37 Old 03-04-2012, 07:38 PM
We have done everything ford has advised on the numerous TSBs and still replace radiators every few months. I own 11 of these and except for 6.0's (which I'm getting rid of ASAP) they are the worst thing I have ever seen. Ford now tells me that the cause of the failures is the excessive cycling of heat from the EGR and with current radiator technology they will continue to fail. I bet I've been through around 20 radiators since 2008.
psimpson is offline
