| 6.4L Problems Forum Having Trouble? Post here |
Read my oasis
What is this jibberish, should i be concerned.
The 8c3z - 9a543 - b is for the replacment HPOP that is what runs the fuel injectors.
Has note of 17.4 hours labor. Was a cab off to repair. Other was customers what was "wrong" And what the trouble testing was done and found. The pump info http://www.fordpartsgiant.com/parts/...z-9a543-b.html |
Is the oasis for a 6.0? 6.4's do not have an HPOP.
The P/N in the report is for a PUMP ASSY - FUEL INJECTION
Did not see in the report as a 6.0 or 6.4 |
Report is for the truck in my sig.
2010 f250 6.4 |
Did I help you understand the report ?
My ride is a 07 with 6.0 my bad on the oil pump but that is what Ford replaced to make it run better. Only issue has been the EGR valve. One still needs to keep up the services like oil and filter changes. My old ride was a 75 F100 with 300 six, over 300,000 miles without a overhaul pulling total of 12,000 pounds around the USA with racecar in tow to AHRA events. |
Thanks bud, so they replaced the hp fuel pump.
that is correct
